Replaced 4.7 Eng. Now PCM Code
TNRamGuy
Jackson, TN
3.6 V6
Hi all, new to the forum, I had to replace my 4.7 on my 2002 1500. A short time afterwards I got the P0601 code and Chk Eng light stays on. I assume the PCM issue is due to eng. replacement. I have no symptoms and truck runs fine. Is there a simple fix or will I need to replace or reprogram the PCM?
Thanks in advance for any insight!
HemiLonestar
Navy Badge Coast Guard
MD
That's a code for an internal PCM fault, usual fix is replacement.
TNRamGuy
TNRamGuy
Jackson, TN
3.6 V6
Is it common this happens when you swap an engine? Or possible just a coincidence?
HemiLonestar
MD
Normally don't frag a PCM doing a simple engine swap unless some stray voltage found its way to it.
