replaced almost everything, still no brakes
Discussion in 'Exterior' started by PaulPool89, May 9, 2012.
Sponsored By: BAK Factory Outlet
  1. PaulPool89
    PaulPool89 Junior Member
    29
    11
    May 9, 2012
    Ram Year:
    2010
    Engine:
    5.7 V8
    yes I bench bled them properly. Just changed the master cylinder again on the off chance I got a deffective one. Still the same issues. And no I did not have my motor running while I bled everything.
  2. Bigtman07
    Bigtman07 Registered User
    9,325
    228
    Jun 28, 2010
    Piqua, Ohio
    Ram Year:
    2000
    Engine:
    Cummins 5.9
    Well you shouldn't have to have it running to bleed the brakes. At least I never have and I have super freaking brakes. lol Dude it sounds like there is something super funny going on. I'm almost wondering if there isn't a pin hole in the line somewhere. nay ouf you buddies happen to have some brake line laying around? Run some trial lines to the wheels and see if it fixes the problem. If it does. Welp sounds like new lines are in order.
  3. undgsx-R
    undgsx-R Junior Member
    11
    Feb 4, 2012
    Grand Forks, Nd
    Ram Year:
    1997
    Engine:
    5.2
    I guess I have never checked but is it possible to have the calipers on the wrong side?
    Sent from my iPhone on the fly!!
    Kickkem likes this.
  4. Enshadowed
    Enshadowed Junior Member
    Aug 5, 2012
    Ram Year:
    1998
    Engine:
    5.9
    I had this happen once before. I replaced everything, brake booster clear to brand new calipers. Turn out i had a bad hub, caused it toto ride a caliper, killed all my brakes. Replaced the hub, and bingo.
  5. davemal
    davemal Junior Member
    Aug 20, 2012
    Ram Year:
    1997
    Engine:
    5.9 liter
    I had the same issue with my 97. I tried a trick I read about and it worked. I opened up all the bleeders and let the truck sit until fluid ran out the bleeders on its own. Then I bled the brakes and have no issue now. This pushed all the excess air out of the lines.
  6. Levi2013
    Levi2013 Junior Member
    Feb 24, 2017
    Ram Year:
    1998
    Engine:
    5.9
    Hi I know this is an old post but I'm having the same issue with my 98 and it's driving me nuts!!! Did u find out what was wrong??? Please let me know thank you..
  7. Kickkem
    Kickkem Junior Member
    65
    Dec 7, 2017
    KCMO
    Ram Year:
    1998
    Engine:
    Hemi 5.2 318
    I have seen the situation where the calipers were on the wrong side and there was no way to bleed them since the bleed screws were down instead of up. Just a thought.
  8. Qweedqwag
    Qweedqwag Junior Member
    52
    13
    May 11, 2015
    Ram Year:
    Engine:
    Did you drain the system dry? The ABS system does not like that.
  9. dudeman2009
    dudeman2009 Senior Member
    23
    1,562
    185
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Can we not Necro posts from 2012, please?
  10. Wahrsuul
    Wahrsuul Senior Member Military
    1,280
    1,149
    Nov 16, 2011
    Central S.C.
    Ram Year:
    2009
    Engine:
    And yet how many times do you see someone ask a question, only to be told to use the search function? Old posts are likely to come up. Admittedly, doesn't seem to happen on this forum much, but I've been "yelled" at for it on others.
Share This Page
