Replacement Grille Guard Suggestions
Noel VanSpoor
Everett, WA
I drive a 2016 Ram 1500 Big Horn Eco-Diesel and am not a fan of the stock cheesy plastic louver-style grille guard.
I tried to buy 1 through some online vendor; maybe American Trucks and it said it would fit but did not. It required the honeycomb style grille to attach to.
I like the billet style grilles with the thin stripes, don't need anything fancy with lights and don't want to spend more than $200-300. Any suggestions?
Villalobos
USA
5.7l hemi
There’s lots of options on eBay. You could also spend a bit more and recoup your costs by selling your current grill. There’s a thread about changing to a Big Horn grill. Lots like that look.
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
Unsolicited advice here, but the billet grille I put on my 2001 would sing between 35 and 55 mph and go up an octave at 70. It makes sense since they're like a reed in a woodwind. It wasn't so bad I couldn't stand it, but it's noticeable. My first drive with it, I had to pull over because I thought one of my wheel bearings was going out.
Noel VanSpoor
Noel VanSpoor
Everett, WA
Thanks, good to know. I kind of like the 4 separate section look. I think I can buy replacement grilles for each section. Are you familiar with those at all? I like the ram in the middle and don't realky want to lose that, and I definitely don't want to replace with the big RAM letters or anything like that. Its a woman's truck so I don't want a big burley grille.
RodeoRam
North Carolina
Hemi 5.7 2500 CC
No, the inserts were out of the question because I needed a whole new assembly. I opted for the whole grille because mine was falling apart. The cheap, so-called chrome was wrinkling and peeling off the plastic grille, and most of the plastic attachment tabs were broken. What sealed the deal was when I was going through a car wash, and the bug deflector that was held in between the grille and hood went flying.
The one pictured was exactly what I had been wanting since I bought the truck new - an all-metal grille with real chrome. It's dad's truck now, and the grille still looks good.
I just wish LMCTruck sold one for 4th Gens.
Pull Ya
Cedar Creek, Tx
I am replacing my current stock 2016 Sports grille with an aftermarket grille. In all my searches I have found that almost all the replacement grilles on Amazon and e-bay are cheap plastic replicas that are way poorer quality than factory grilles----however, they are a lot lot cheaper than the OEM. Good luck in your search
Jay
KnurledNut
SemperFi
Sonova Beach
I replaced my OEM honeycomb with this fleaBay replacement. No major install issues, only had to add a couple of tie down points w/ pushpins . I do get a little bit of the black coming off from a nasty bug hit but a bit of flat black paint (1-2 pinhead size) solves the issue.
azcoyote
Phoenix
$20 and time if you plastidip.
can be a good option.
