- Sep 12, 2020
- 45
- 16
- Location
- Richardson, TX
- 2005 & 2014
- 3.7 & 3.0 EcoDiesel
Hey fellas,
I'm changing out the engine & PCM/ECU from my 2005 Ram 1500 3.7L 2wd base model truck with the PCM/ECU and the 4.7L engine from a 2006 Ram 1500. I understand that the VIN and the mileage are stored in the PCM/ECU as well as the engine characteristics and that I will need to get the NEW ECU/PCM updated to reflect that it is now in my truck. I also wanted to get the mileage updated to match the mileage on my odometer (if that is even necessary). The other stumbling block is that the 2006 model year truck that the engine/PCM came from also had electronic locks/key FOB and I *believe* that means it may also have the RFD chip associated it with (SKIM module, maybe?) and that this SKIM function may need to be turned off? My truck has a black, chipless key.
Anyway, that was a longwinded way of getting around to asking my question; do you all have any recommendations of companies where I can send my PCM in and have these services performed? Is there anyone on the forum or supporting vendors that offer this kind of service? I truly, truly, do not want to go to a dealer for this kind of thing if I can help it.
Appreciate any assistance, direction, or advice you can give.
Thank you,
-Matt
Thank you,
-Matt
