Replacing window
keith.C.2313
Indiana
2015 Ram 1500 Sport
Anybody ever replaced a power door window? Particularly the front driver side. Difficult? Easy? Can I do it myself or should it be done professionally? Looked up some videos but most were for replacing the window motor. I already have the window just deciding if I should tackle it or not. Any help would be appreciated.
Sent from my XT1635-01 using Tapatalk
Tdjma
It's not too bad just slide a stop to keep window in place you should see 2 bolts holding window track on maybe 4 2 each side then you can remove frame bolts and remove it depending on year it may have a cable which means the whole Assembly gets replaced or the motor only on some Assemblies
Racer_X
I've done it. You need a 2nd set of hands or some good suction cups to hold the glass while you get it attached to the mechanism. Pull the door panel, remove the power window switches from the panel and reconnect to the harness. Roll the mechanism down and there are access holes to get to the retaining nuts, 10mm.
Then remove the old window bracket. Insert the new glass thru the window channel and use the suction cups to hold it in place. Reattach to the mechanism, replace the retaining nuts, remove the suction cups and roll it down and check for any obstructions. Roll it up and down a couple cycles to ensure it works properly. Reassemble door panel and reattach window switches properly. Have your favorite concoction and celebrate
Sent from my LG-H918 using Tapatalk
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
I did a DYI Youtube video, step by step and part of it involves window extraction. Located in this forum's 4th Gen DYI section, here. Good luck!
keith.C.2313
keith.C.2313
Indiana
2015 Ram 1500 Sport
Thanks for the input guys! After reading and watching your replies I think I'm gonna do it myself. Knew I'd find an answer here.
keith.C.2313
keith.C.2313
Indiana
2015 Ram 1500 Sport
Just got done doing the window. Your video helped a lot. Thanks.
crcraft
