Ridetech level tow
Fieldoc
Installed their rear air bags in place of my coil springs. Also put in Timber grove auto air leveling system. More than pleased. First off the ride empty is smoooooth. And now when tow or have weight in bed stay level automatically. Only drawback is price which is roughly 1600 when done and that's installing myself which is not hard either. But went this route cause previous ram had air suspension and wanted the ride that had and now have again. I did try Steves coil replacement air bags but they were rougher than my coils for some reason, I might be to picky because his products are excellent. He is great to work with also.
Ramcharger60
2016 crew cab sport
You probably had too much air pressure in the timber grove bags. I have their 6"drop CRM and also the compressor system. On my truck the ride is fine unless I hook my rv up then it becomes stiff, which I want anyways with a load
Sent from my SM-N960U1 using Tapatalk
F
Fieldoc
Tried different psi as had them hooked up to fill manually first and did not matter where at just did not like them.
joshhhh
