rigid cubes
ocwill1
Severn, MD
5.7 eTorque
Hey all. Just installed rigid cubes (white and amber) in place of factory driving lights. Got the Rigid adapter plate, and installed in hole. Everything looks good, however, led white lights hooked to factory harness will not stay on. I have a 9006 to rigid adapter harness for clean install. I am assuming I need an anti-flicker module. Is there a module that will be plug and play. Do not want to cut any wires....
WilliamS
Tampa FL
Need a Can module/resistor of some sort. The truck needs something to tell it that the lights are pulling the proper power, if not it thinks there is an issue and shuts it down.
Litew8
Near Youngstown Ohio
4.7l
Im surprised. Mine are great. I get one little flicker when I turn them on but no issues. Lets see a pice6d073478c45d840c42c7d06fbb91108.jpgd21ab8dd799ceb7503e9e5fd54d05b6a.jpg
Sent from my LGLS775 using Tapatalk
ocwill1
ocwill1
Severn, MD
5.7 eTorque
Here they are...
JBYRD8
Cummins 6.7
Rigid (driving beam) for lows
Rigid (spot beam) for highs
Wiring wasn't bad.
Made a metal mounting bracket and wrapped in carbon fiber. And my headlight housing is paint matched.
Aileron516
Have the sidetracked offroad cubes and zero issues with them in my fogs (13' 1500)
ocwill1
ocwill1
Severn, MD
5.7 eTorque
you are lucky, 15+ they changed things up and have to run anti flicker modules for the heads, and apparently the fogs as well.. no biggie, just a few more days to get the new adapter cables in
Rzrman328
The treeline
Looks mean.
Wiring wasn't bad.
