Rim size help ....urgent
ramhunter9
P-Star Jeep Wrangler
Im looking at new rims .... I have no idea what I have now but I like how they stick out flush with my fender flares . All I know is my rims are 8 lug and are 20"
The rims I found are this size ... does it sound right . Im running a 35x12.50-20
# Size: 20x10
# Offset: -12mm
# Backspacing: 5.07"
ramhunter9
ramhunter9
Anyone !!
ramhunter9
ramhunter9
I dont want to just hear im good ...lol Expaline it to me I want to learn
ramhunter9
ramhunter9
and will a 20x10 be a ok rim for a 12.50 wide tire ?
ramhunter9
ramhunter9
I did that .... dont understand dammmit
ramhunter9
ramhunter9
never mind I ordered them .... if they dont fit im banning you ..lol
txbass06
NE Texas
5.9 Magnum
A 10" wide rim is just fine for a 12.5 wide tire. Hell, I'm running 12.5's on my factory 16x8's lol
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i don't know **** about this..........but I know you are going to want to know what the backspacing is.
4X HEMI
Lancaster County, PA
I believe the 2500's are 20x9 wheels, not sure what the factory offset is on the stock wheels but it appears you have aftermarket rims on it now.
Do you know what the offset is on your chrome wheels? ... The offset works like this: A positive offset will take the rims closer to the truck, as it goes to zero and minus offset numbers it takes it away from your truck!
The 5.07 backspace should be fine, I believe most 2500's are 5 to 5¼" backspace, the -12 offset will bring the wheel away from the truck so it should be a great set up.
As for the width of your rim, 10" wide wheels are perfect for a 12.5" tire.
The Assassin
B-more careful, Murderland
The 5.07 offset should be fine, I believe most 2500's are 5 to 5¼" backspace, the -12 offset will bring the wheel away from the truck so it should be a great set up.
Thanks Harold, I was trying to find a simple way to explain it, and failed lol:roflsquared:
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
10"(w)-5"(bs)=5" with a -12mm (.473") Offset. You are looking very close to 5.5" from the hub flange to the outer edge of the rim..
Reticle918
