rim tire help
workd4it
Ok guys this is my first post about my first 2016 dodge 1500 quad cab express 4x4. I have a chance to buy a set of 33-12.50-20 rims and tires for a decent price but not sure if they will work. rims are xd. I am also going to be doing billstiens up front prior to install of these should I grab them. anyway I am attaching a pic so any help will be great. I love these trucks. Gonna also be doing mods through out but doing tires rims first as it really changes the over all look.
Shane1990
He I 5.7
What exactly are you unsure about?
MADDOG
Living in a Firepit
6.4L HEMI
What is the bolt pattern, wheel width and offset on the rims?
W
workd4it
they came off 2015 express ram and are 33-12.50-20 not sure what offset is I can find out though. I want to no if they will rub on my 2016 express?
Shane1990
He I 5.7
They should not rub because the factory wheel size on an express is a 33 so you should be good
MADDOG
Living in a Firepit
6.4L HEMI
yeah, get the offset just to be sure.
I'm not worried about rubbing on the top of the tire or as it clears the front or rear of the wheelwell because, as Shane1990 said, the stockers are 33's.
But if the offset is wrong you could have some rubbing inside.
Shane1990
He I 5.7
Was anything done to the truck the wheels came off of? If not then you most likely will not have any trouble
W
workd4it
tire rim help
yes owner says he put very cheap 2.5 level spacer in but also said there is no offset they did not stick out at all. I will be leveling mine so thinking they will work just wanted to check with you guys. gonna get billstiens for front if I can find them.
Shane1990
He I 5.7
You'll be fine. Be sure to post pics!
gville35
