RPC Phone Holder Mod for Bench Seat
AFMoulton
Nuevo Mexico
Alright, This is my first DIY/How To post, don't beat me up too bad. First Wade sent me a Large Phone Holder. Which is totally kick ass. I had a Pana-Vise lying around from an old car. So I was trying to figure out where to mount it. I decided on the deep hole that would sit right above the 115VAC outlet on most trucks, but mine doesn't have it yet...... Here are the pictures. I used 3M tape to mount the Pana-Vise to the truck and the holder. It works great because it is right above the outlet so I can charge my phone as well!
AFMoulton
AFMoulton
Nuevo Mexico
Round #2
EDIT: I have no idea how to rate the photos. Some one who is much more computer smart will have to help me.
neloms
2016 Dodge Ram 1500
3.6L V6
Creative, but isn't that a long reach?
AFMoulton
AFMoulton
Nuevo Mexico
Not really, its almost perfect for my reach. Plus, I just wanted it to be able to use my GPS on my phone and have it at a glance.
AustinB
Banned
San Diego, Left Coast
Lol you guys and your phone holders.. My truck has one built in already, and it doubles as a cup holder. :)
Anyways, good initiative/idea, but just don't put too much faith in that 3m attatched to the plastic inside.. I tried something like that and ended up going with screws for my spod mount.
My phone holders :)
IMO
AFMoulton
AFMoulton
Nuevo Mexico
IMO
Thanks. I will probably adjust this as I get more used to having it in the vehicle. This is round 1 of Modification. LoL, I am always changing things, which is why the 3M tape. I will wait till I get my HF Ham Radio set up installed, then move things around as required.
Avgas
2015 Express
3.6 Pentastar
You should mount that higher if you want to use GPS and not crash.
cgeorgemo
Joplin, MO
3.6 Pentastar
Bayou goat mounts....
big_red06
2014 Bighorn
This is the route i took its called the iOttie Easy One Touch 3 (V2.0) got it from amazon works great in my opinion and keeps my Iphone 6s plus secure in place and easy to get to it mounts via a very strong suction cup and is fully adjustableIMG_0163.jpg
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I put my iOttie mount in the same place. Even hard wired the power supply in behind the accessory plug and routed the cord up through the little tray above the radio.
Works great and everything is out of the way.
Sent from my LG G4 on Tapatalk.
big_red06
2014 Bighorn
I put my iOttie mount in the same place. Even hard wired the power supply in behind the accessory plug and retired the cord up through the little tray above the radio.
Works great and every thing is out of the way.
@ Mpgrimm2 can you post pics of that wiring setup might want to do this myself i dislike the wires everywhere for my phone thanks
Mpgrimm2
Preferred Vendor
SC
5.7L
Sure thing. I hate the wires everywhere also. I didn't take pictures of it when I did it, but I will post back with what I can, just give me a day or two.
Mpgrimm2
Preferred Vendor
SC
5.7L
Here's some pictures of my iOttie wireless Qi charger without taking the dash apart (no time right now).
Some notes:
- Basically I carefully split open the car charger's plug and soldered (2) 8" wires (pos & neg) on to the board inside and routed them out through the front pin that I removed from the charger (removed the outer neg pins also) and crazy glued the charger back together. Then terminated them with male & female quick disconnects (for polarity).
* it is possible to get a corded socket with 2 clips for connection to a battery post and cut the clips off so you don't have to split open a charger. Then use the socket behind the dash (to bulky for my tastes).
- Then spliced in (soldered) 2 sets of male/female (pos/neg) leads onto the backside of the 12v 'switched' outlet's plug wires (it's possible to get the pins out of the connector for soldering and sliding heat shrink over the splice).
* 2nd set is for my portable XM receiver w/FM transmitter that has a lifetime subscription (in between RA4's subscription times)
- next I connected the charger to the new terminals behind the dash, zip tied it to a frame piece and routed it up through a hole I made under the rubber pad in the dash's upper tray (easy to hide later with a new rubber pad if needed. Also notched the little rubber pad).
big_red06
2014 Bighorn
Some notes:
thanks im going to look into doing this
