Rpm issue
Ifish1002
I have a 2011 big horn and I drive with the MDS off and when it's in 5th gear the RPMS drop under 1500 and It jumps up and down very little and I have a exhaust so you can hear the RPMS jumping.. any suggestions?
huntergreen
Marine Corps Navy Badge
Try driving with the MDS on . If it doesn't change check your throttle position sensor.
7777xm
Covington, GA
Torque converter lockup.. Are you just using manual gear selection to avoid MDS?
May want to just get a tuner and turn off MDS to avoid this.
Sent from my Pixel XL using Tapatalk
I
Ifish1002
I manually do it on the stick
EZDZZ
I have a 2017 ram1500 shifted like trash truck only has 4000km and previously having a 2014 same engine and trans I knew something was wrong. Turns out there is a tsb for software
