Running Boards / Steps for 4th gen Crew Cab
Jodman012000
Massachusetts
Hi, I'm going to be putting new steps on my Crew Cab, 2016 Big Horn. Any suggestions?
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
AMP power steps.
Sent from my SM-T350 using Tapatalk
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
VCorleone
Chester County, PA
3.7L V6
These boards by APS. Solid, so there is no way for water to seep in and cause them to rust out.
Did them myself. Easy install. On my 2017, only the front holes under the rocker panels had a threaded piece in place. Use a same sized self tapping screw to cut through the paint and gunk in the threads when you do the install. The bars come with all the pieces you need to install, except a self tapping screw...that just makes it easier and prevents you from damaging the install screws or the threads on the rockers..
https://www.amazon.com/APS-Premium-...SPVVZJTMKA9&psc=1&refRID=KR60MT6BVSPVVZJTMKA9
JEWRAM
Alaska
If you are going to get power steps go with RBP. Dual motors on both sides. And a 5yr warranty
Lowrider357
