SAS 2008 3rd Gen (Steering angle sensor) not working
zsoltinak
Hungary
5,7 Hemi
Hi!
we tried to replace the clockspring (is with the SAS together). Due to making photo from the part number we disconnected the old one and put it from the original position.
Now ESP BAS is lighting… it should be put it back to the original position and calibrate…into the 0 position of steering wheel.
It´s an older RAM, 3rd GEN 2008, with optical SAS.
Does anybody have the same issue? How can be fixed?
Wich OBD tool should be used to calibrate the sensor?
Otherwise, I do not find unfortunately a clockspring for this model. Part number is
05082062AJ
Thank you for your support
rockyj69
