Shift Pattern ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
2015 1500 Pentastar V6 8 Speed transmission ! All seems fine BUT it does seem to take it time shifting to 8th. Seems when it drops down, whether hill or acceleration, Stay around 2k RPM,longer then I think it should ! Avg cruise about 1500/1700 RPM Has there been any TSB on this transmission ? My MPG IMO is good 20/21 combo and highway maybe 22 mpg . Am I over thinking this ? Thanks
huntergreen
Marine Corps Navy Badge
Would this shifting behavior be influenced by the gear ratio ?
I would expect a bit better hwy mpg. My hemi will see 21. Mpg on the highway with my hemi if I stay at 70 mph.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have 3:21 gears.Stock size tires No lift.. So far my best MPG at 75 mph has been 23.4 but avg 21/22 . IMO not too bad :) And from what I have read the Hemi like yours runs the same or close! Just curious about the RPM and shifting on mine! AT best if it did need a transmission flash I might gain 1 or 2 mpg. But that transmission seems to take its time shifting too 7 and 8th. I have heard the flash was on the Hemi but not sure what gears or transmission it was for. I think 2014 and below!
Quyonmob
Canada
Takes forever to hold 8th with 3.21s and my pentastar. The should have never spec’d It that way, 3.55 should have been minimum.
That said, your hwy mpg isn’t great, I see around 24mpg but at 70mph.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I was figuring a little more MPG with the 3:21/ But so far the best I ever got was 23.4 if memory is right lol I would love to see 24 MPG all the time :) Will see what I get with my new tires and summer gas . We are still on winter blend . My next trip I will cruise at 70 mph and see if that makes any difference !
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Mine doesn't stay in 8th most of the time on the highway. I am averaging 19mpg after my lift and 35" tires. Could it be the trans or maybe the 3.21 rear end causing this?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Even the 5.7 struggles to hold 8th with 3.21 gears stock, FCA was looking for class leading mpg with this combo.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks everyone for your info. I wonder if a re flash of the transmission would help ? Now we are starting to get summer gas again I am averaging 21 mpg around town. But I am sure I will still see a Hwy Avg of 22 mpg+ at 75 mph. My next trip I will try and keep it at 70 mph max and see what happens :)
huntergreen
A lot of variables come into play. I'm your case, on a hwy trip, if most flat terrain, I would think you should see 25 mpg.
ThunderMug95
North Prince George, VA
I just look at it like this, its basically a 6speed with a double Overdrive transmission. Both 7/8 are sub 1:1. I just accept that it is going to shift in and out quite frequently. As for ECO, religiously set it to 8 to keep the annoying MDS in hibernation. Sometimes if I know Im not going a route that is at least 55mph, I just select 7.
The best thing for mpg is being smooth and picking your lines anyways. See the lane change 1/4 mi away and not get pinned in so you have to brake and then accelerate. Just my 2 cents.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Struggles? Im in eco in 8th for hours on my drives with that setup..
What speeds, my FILs used to hunt gears and was apparent due to muffler swap from 60-70mph with wind or any incline.
ECO just means you’re in an efficient mpg state, does not necessarily equate to 8th gear or MDS active.
Troy Gillis
Alberta, Canada
I travel in the 65-75mph range, and know Im in 8th as I was taught to downshift for slowing down over braking.. When I tap the down shift, it comes up in 8th gear on the dash.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I just let off the gas when coming to a light but will try the down shift button and see what I find :) Thanks for the idea
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Good info but the only thing flat up here in Maine is my head :O Not big hill but not flat like Fla. lol
CVX20
Ont,Ca.
2019 Classic Express
The motor doesn't have enough balls with that ratio to keep it in the big gear.If it did go into 8th you'd be lugging the motor and get worse mileage.The beauty of the 8 speeds is that it keeps it in the right gear with the power available to get the best mileage.
Reticle918
