KLook
I just pulled into my drive and threw it into park, column shifter, went to pull the key out and it stuck, so I wiggled the shift lever as I usually have to put it back into gear and then put it in park again. Forgot to restart the truck so when I pulled the key out, the lever is in an odd position and will not move.....even with the key and the truck started......
2014 3500 Tradesman......any help out there?
Kevin
Kevin
