2012 Ram 3500 cummins Mega Cab Tranny problem:
Demon Hunter 441
Lakewood Co
I need some help or advice or both. I jut put in a new valve body in my 68RFE put it all back together and went to start it and nothing. The shifter is in park but it shows that it is in Reverse in bright red. I drained everything back out took the valve body back out everything seems to be in the correct position reinstalled it making sure the shifter tab is in the slot in the valve body and same damn thing. shows in reverse bright red even thought the shifter is in park. Any kind of help would be greatly appreciated. Thank you in advance.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
I would check all the electrical connections to be sure a pin is not dislocated or not in tight enough or a wire that has been pinched or cut...
Steve58
