ramirezcf619
I have a 2003 with 5.7L 2WD and recently it started doing some scary stuff. One day, the tranny started slipping. From a stop, I accelerated and 2nd gear went in a little rough then when it tried shifting into 3rd, it just reved up and gear would try to go in but revs just kept fluctuating. I pulled over shut the truck off and turned back on after a little and as I pulled away, i did same thing. Luckily, I was close to home to took home and parked it and left to work on other car. 10 hour later got home and took truck out on test run to see if it was electrical issue, and truck ran fine. Ran great, smooth shifting, for like 6 days and today it did it again.
If it was a mechanical tranny issue, I believe it would do it all the time, but I'm no expert. Same thing with CATs. Any ideas, sensors to check, TCM? Any appreciated.
