Shocks
fordram guy
hemi 6.4
Hey guys I have a 2019 ram 2500 6.4l was hoping to see what would be the best replacement shock to buy for all 4 corners
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
only 2 years on the shocks & you are shopping already ?
You must drive it a lot.
My shocks quit functioning at 60,000 miles
I will be looking at Bilstein
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I have almost 90k on my 16' & my shocks seem to be still going strong for what they are. I tow heavy about 20% of the time too. I guess if I was going to keep it I probably would replace this winter with some Bilstein's. Everybody seems to like those on the HD trucks.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I had Bilsteins on my 2018, I have Fox on my 2021. Fox's see
I had Bilsteins on my 2018 and have Fox on my 2021. The Fox seem to be much better. Stock shocks are ****, and waiting until they wear out is like waiting for someone punching you to get tired and quit before you finally punch back.
mtnrider
Georgia
What is the perceived problem you are trying to rectify? I doubt your shock are worn out already.
GTyankee
3.0 ecodiesel
Most Bridge Approaches are square with the road that you are traveling on. Like if you have a hose & you lay it straight across your driveway, then drive over it.
Both front tires touch the hose at the same time.
Bridges usually don't sink down, but the 20 or 30 feet of pavement, just before the bridge does settle down.
When you hit that bridge that is square to the road, your vehicle lifts straight up & you feel it as if you just ran over a board.
If the bridge approach is at an angle to the road & is at a different height, you are tossed from side to side in the seat when your shocks are not functioning well
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
Are the adjustable 5100 bils an option for this truck to raise/level the front end?
joshuaeb09
Medina County, TX
The bills aren't bad for the money and honestly what makes the off road package worth the cost if looking for something better stock when shopping 4x4's. Imo the stock shocks on the non Off-Road package trucks suck having driven both on lots of gravel roads. My old man had a '19 6.4 tradesman basic 4x4 no frills truck that blew both front shocks after 15k miles going to/from the property daily. Considering how he drives I'd very much say the truck wasn't abused at all, just had to do a lot of miles on gravel and occasionally towed a tractor or their RV in the summer. The CTD w/off road package that replaced it has had no such bad luck, rides better, and really is what made me make sure my Laramie was an off road package truck. When I eventually do some front Thuren springs I'll probably go with the 5100's for them and hope I don't get the itch for King's again like my old 1500 lol.
Dinky
Oregon
Depends on what you do with your truck. One thing no one has Said anything about is install a aftermarket front swaybar.. it will change everything
Zoe Saldana
california
6.4l
I'd do a new steering stabilizer before that.
Dinky
Oregon
I did it all. Steering stabilizer upgrade is nice but the oem does a decent job. Thuren active sway bar changes the over all ride quality imo. You won't break your window when going over a speed bump at a angle.
