Fnjoey
What silicone are you guys using to seal up around the rear window? Had it replaced once already, and noticed that it was leaking in the dead center of the window now, no cracks in the frame, I put a new seal on the 3rd brake light and antenna is dry. When I was checking I noticed the window sealant in the middle of the window isn't as thick as the rest, so I'm assuming whoever the dealer had install it, started and stopped at the top of the window instead of the bottom.. but regardless, I don't feel like dealing with it, so I'm just going to run a bead along the top of the window, but unsure what to use. White truck, but I need something uv resistant, I was thinking black, because clear tends to discolor over time. What's everyone's opinion?
