Size of Tires on 3 inch lift?? Help?
estebanespinoza24
4.7 V8
I am riding on a 3 inch rough country suspension lift and wanted to know the biggest size tires I can fit in without rubbing. Thanks in advance for the help. And if you have pics it would greatly be appreciated.
Yo Nadz
St. Louis, MO
Hemi 5.7 Sport Crew Cab 4x4
I'd say 35s. I rub a little at full lock levels on a 3" body lift.
NWRQC
Is this a 2wd or 4wd? I had a 4" lift w/35's on my 05 4wd with no rubbing. Wheel/tire width and wheel offset play a role in it as well.
E
estebanespinoza24
4.7 V8
I have a 2wd. Ok I see. Hopefully it won't but from what I have found, that if I add spacers that could solve the problem if it rubs. So I'm hoping that could work.
quietpeen
2021 TRX
Hellcat
I would also say 35's will be a good fit
phorrestphire
