Sliding bed rack
jperham1968
hey all, curious if anyone has purchased or created for themselves a sliding truck bed rack. Something that can be pulled out on rails, making deeper stored items more accessible. I’ve seen some online as cheap as $100 all the way up to 2000, curious if anyone has tackle this timeselves.
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I keep my extended snow brush in the truck bed all year. When I can't reach something in back and don't want to crawl in there, I use the snow brush - $5.
An old fire poker or anything with a hook on the end (old broomstick with a long bolt drilled through the end) should bring most of what you need to the back of the bed.
Zoe Saldana
california
6.4l
The best solution and most versatile for me are plastic bins and a small step latter. The step latter can be used to get into the bed or access things from the side. It is also good for access to the engine bay. I have a 2500 with a tonnou cover.
jperham1968
jperham1968
That is pretty interesting. My only concern is the added weight. Very very cool. Great work
Zoe Saldana
california
6.4l
Here is an idea. I've been wanting to make something similar as well.
Nice work. But with the drawers you are limited to things that can fit in them by the width and depth. Electric hand tools would work.
https://www.homedepot.com/b/Automot...xes-Truck-Bed-Storage-Drawers/N-5yc1vZ2fkok7y
You can find totes at Walmart that fit perfectly under your tonnoue cover at walmart.
https://www.walmart.com/browse/home/plastic-totes/4044_90828_1230056_1959450_9226761
You can load/unload them into your garage and take what you need.
Not sexy but functional.
joshhhh
