Sliding rear window lock replacement
gapalm
Glen Burnie, MD
3.6 L
I have a 2020 1500 Big Horn with a manual sliding rear window. The lock is missing. The dealer only has a part option for the entire window. Where is the best place to get a new lock?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
yeah, but with so many choices I am concerned that I'll wind up with the wrong part.
How about if I type in "2020 Ram pick up sliding window lock" and it comes up with this:
AI Overview
Replacement rear sliding window latch/lock for a 2020 Ram truck (1500-5500) is commonly found as part number 5093518AA. These are durable black plastic latch assemblies designed to replace broken or worn-out center locks, with prices typically ranging between $13 and $27 from sellers on eBay and Walmart, ensuring a secure seal for your rear window. [1, 2, 3, 4]
  • Part Number: 5093518AA
  • Material: Durable Black Plastic
  • Fitment: Fits 2020 Ram 1500, 2500, 3500, 4500, 5500
  • Function: Replacement keeper latch for the sliding rear window
  • Common Source: eBay or Walmart listings for "Dodge Ram Rear Window Latch" [1, 2, 3]
For installation, you may need a strong adhesive or to ensure the latch snaps securely into the existing frame. Note that some listings specifically say they are for 1994–2001 models, so it is important to confirm compatibility with the 2020 model year via the 5093518AA part number. [1, 2, 3, 4, 5]
Wasn't that hard... took just under 5 seconds cause I don't type well. PS: Mopar calls it a backlight keeper.
G
gapalm
Glen Burnie, MD
3.6 L
AI Overview
You make it sound easy, but when you search Mopar for that part it doesn't exist. When you search Amazon, 4 results are returned and they all say it doesn't fit the 2020 Ram 1500. Sounds easy, until the result don't work. Even the RAM dealer was only able to give a part number for the entire window and they used the VIN to get an exact match.
