Small lift track bar drop issues
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
So I will be installing new stock height coils and a 2.5" spacer and I have seen the 2-3" track bar drop bracket that attaches to the stock bracket on the axle and I concerned with drilling 2- 1/2" holes in the stock bracket to attach the new bracket:3681700201_eef6d1e2
Im worried it will greatly reduce the strength of the original bracket and I don't know if I trust just welding it to the stock bracket with a small wire feed welder
Are there ANY other options for track bar drop brackets other than the 2-3" made by TC that attaches to the stock bracket on the axle???
Thanks guys!
Merc225hp
NA
truck
gas
It will be fine just drill and bolt it up no welding on it.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Unless you're putting a longer pitman arm on you want to run an adjustable track bar, not a track bar drop bracket. Dropping the track bar without dropping the drag link will cause bump steer issues because the geometry of the front end will be off.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Im trying to center the axle under the truck after I lift it and that's why I am thinking about the bracket..
i've herd of bump steering before, can anyone comfim I will have this issues?
Merc225hp
NA
truck
gas
You will not have bump steer and there is no drop bracket for the frame end thats works with that small of lift.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Bump steer is a ***** even without lifting. Hell, I'm stock and have real mild bump steer
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Talked to tuff country and what they said is that the 2- 1/2" holes shouldn't be an issue because the track bar doesn't have alot of stress/weight on it. He said it just holds the axle evenly between each side of the truck and doesn't have direct load bearing weight on it
What do you guys think?
Steve58
