Spacers or bilsteins
Bigge2511
just got a 2019 ram1500 and wanted to do a level kit. I don’t off road so I was wondering are the spacers ok or will I have issues ?
ttthiel
Mid Michigan
100% bilsteins. Spacers affect the suspension geometry more than bilsteins affecting your ride quality in a negative way! You will not regret bilsteins!
buddy guy
alberta
Bilsteins will improve your handing and some believe give you a better ride (or firmer ride anyway) having mine for 2 weeks, it does feel more solid but still a good ride) spacers up front are a cheaper, but not as good or better way than Bilsteins to get the job done. no risk to other front end components if you run no more than 2.1 as I did. 2.8, you may need to change your upper control arms.
ttthiel
Mid Michigan
Give your billys a couple more weeks and they will soften up a bit!
Little Webb
Mn
I am thinking about leveling mine too. Are you doing it with just the bilstein shocks or small I missing something?
buddy guy
alberta
just the Bilsteins for me. leveled out perfectly. if i wanted to add a rake i would have got rear spacers as well. but i like it level. i don't tow, only heavyish loads i have is going to the dump occasionally. i probably keep 50 lb of stuff in the back on an ongoing basis.
Little Webb
Mn
5100s?
buddy guy
alberta
yes. 2.1 inches on mine gave me 39.5 i think it is, front and back.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Bilsteins are not available yet for the Euro front end abominations as the towers are higher up. Running 4th Gens at 2.8 probably gets you level with *OEM height on a 5G.
J/k on the front end, there is one style combination I would actually consider.
BigRed4x4
Mid Michigan
I have had the bils set at 2.1 and my buddy did the spacer level about the same time 2 years ago. No complaints on ride form either. I have about 10k more miles than he does. I had to replace both lower ball joints 6 months ago and right side upper ball joint and UCA a few months ago and now have a wheel bearing going on that same side. Not sure if all that is connected. He hasn't had to do anything yet.
edit: I am talking about 4th gens
Dnutt
Wv
What kind of spacers did your buddy use??
BigRed4x4
Mid Michigan
I think it was a rough country kit
A quick update though since my post on July 25. He had a wheel bearing go out. Doubtful that it has anything to do with his level though.
SilverSurfer15
Most of that has to do with driving style and wheel/tire combo more than anything.
bmireault1980
