spark plug tube seal
desert01
tx
hi 2016 5.7 changing plugs pulled coil on number 3 aft plug. had oil in tube does value cover have to be pulled to change tube seal
jws123
nj
Yes pull valve cover honestly you should do both while your there if one leaks other one is behind it they sell the gasket in a kit for both sides.
D
desert01
tx
i have mopar extended warrantrey it should be covered maybe lol
HuskerRam
Air Force
Tucson, AZ
3.0 Ecodiesel
It does. I just did it this morning because I had some oil in the aft tube of #8. Didn't look bad for 76k miles.
Kmiko
