spark plug wires ?
Mikeyn23
does anyone know where to get the wires that just go from the coil pack to the sparkplug that's right next to the coil so you don't have to run the wires across the top of the enging ? like the ones in the pic ?
search
JPT
NY
2015 Big Horn
You can make them yourself. At any auto parts store, look for the wires kit where you attach the end yourself.
M
Mikeyn23
By any chance do you remember the name and model number of them idk why but I enter my vehicle and it keeps pulling up wire set for Chevy big blocks lol
Ajwalk2008
Springfield, il
I know they were Taylor wires. Give me a little while I'll find the part number
yoda
They ran the wires from the factory like that for reason , puts less load on the coil driver inside the pcm, do you have a factory pcm? Maybe it turned out not to be an issue with factory pcms.
Ajwalk2008
Springfield, il
These are what I ordered TAY-72641. That is a summit part number
Ajwalk2008
Springfield, il
Pretty sure I've never seen or heard of this being factory
yoda
No its not, I am saying changing it to this setup, from the factory setup, with the long wires that go across the intake, puts more load on the coil drivers in the PCM
M
Mikeyn23
sprak plug wires ?
so is this safe to do ? lol
JPT
NY
2015 Big Horn
It's more of cleaning up the engine bay
Sorry. I didn't reply properly.
I'm saying I don't think there is any issue reducing the length of the wire, because the loss of power between a short cable and a long cable due to resistance would be about the same.
yoda
Its not the resistance of the plug wires. The coil packs fire every engine revolution, not just on the compression stroke. So by running the wires across to the opposite cylinder in the firing order, each coil pack is only firing 1 spark plug that is under compression. It takes less K.V. to fire a spark plug that is not under compression.
I would not do this mod unless allot of people have tried it and have verified it does not shorten the PCM life.
They didn't wire them from the factory like that because they had allot of extra plug wires to use up.
I learned about this back when I went to school on the first gen. Hemis. Like I said, maybe in real life it turned out to be a non issue. Personally I wouldn't chance it.
JPT
NY
2015 Big Horn
I would not change the designated coil to cylinder combo. If that is what you are saying then yes. I am simply saying shortening wires doesn't change the amount of spark.
yoda
Agreed.
I am talking about the picture of the HEMI submitted by the OP. and what the OP is considering doing on his truck. I would not do it and chance damaging my PCM
M
Mikeyn23
ajwalk2008 how long have you been running your wires like that ? have you had any problems
Ajwalk2008
Springfield, il
Just short of a year now no problems at all knock on wood
Raadz
