Speed volume
liljohn30
Atlanta
6.4 hemi
Has anybody been able to hack the speed sensitive volume adjustment to make it always on
Bob Macknight
surprise az
6.4hemi
no need to hack just go into setings and scroll down to either audio or engine settings
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Explain please
There is a an option to set the level, any selection 1-3 leaves it "always on"...
liljohn30
liljohn30
Atlanta
6.4 hemi
I go into both my see audio but nothing to make speed audio always on
liljohn30
liljohn30
Atlanta
6.4 hemi
Ok I understand I have it one level 3 But when I drive the truck to come to a complete stop or slow down considerably I can hear the volume decrease I was hoping to avoid that
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That's how its supposed to work. It gets louder as you go faster to compensate for wind/road noise. If you want it to stay the same volume at all times you must turn it off.
bhonshell37
Washington
Question? Is there supposed to be a noticeable difference in volume change with one window down. I have never heard a volume change.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I don't believe it monitors ambient sound level, only current speed.
liljohn30
liljohn30
Atlanta
6.4 hemi
I think you’re misunderstanding I want it to be the loud as it can possibly be even when I’m not moving I don’t know if there’s a way to trick it so I think you’re always going fast And yes there is a considerable difference when you’re driving when you start off you can hear the volume go up
liljohn30
liljohn30
Atlanta
6.4 hemi
The factory basic radio is so so volume wise ...with the speed option on the volume is better and I can live with it for now...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
What?
rod from md
northeast maryland
my understanding is the radio has a certain "max" volume...the speed control settings will essentially do what we did in the old days..reach and turn it up when the car noise went up, and then turn it down when we stopped.
as we age, somehow we have the idea to turn the volume down to look for signs, addresses etc.. like that makes us see better somehow LOL
rule18
Admin
NY
2017 Rebel
:happy175::happy175:
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
LOL, you seem to have confused yourself
You need to turn that feature OFF then. That way the volume stays where ever you set it to
rojo_143
So @liljohn30 I believe you misunderstand what the speed option volume level is doing. It does not make the radio output any louder than what the factory radio is capable of. All this function is doing while it is active is essentially turning the volume up automatically the faster you go. So as an example... at a stop sign if your volume is set to 15 then speed up to 55mph it would auto adjust to say 20. This function will not exceed any volume level that that the factory radio is set to with the speed option disabled. If your goal is to be as load as possible at all times then disable the function adjust your equalizer settings up a bit and turn the volume knob to your desired level.
