Spewing fuel out filler neck when done fueling
My2010Ram
Nampa, Idaho
Hi all, in the last couple of months when I go to fill my truck up at the gas station quite a bit of fuel has started spewing out of the filler neck when the tank reaches full with the nozzle still in. The pump shuts off and then like a 1/8 of a gallon on fuel coming flooding out. There is no problem filling the truck at the pump, it doesn’t take any longer than it used too and the pump doesn’t stop itself from pumping until the tank is full. When I google this information all arrows are pointing to the tank vent valve as the most likely culprit. Sounds like if it was the charcoal canister or the evap purge valve I would struggle to actually fill the tank up which isn’t the case. The truck also runs great, no weird/ rough idling, fuel economy could be a little better but I attribute that to stop and go traffic. Anyone ever run into this before or know the fix for the problem?
M
My2010Ram
Nampa, Idaho
YES, start listening for gurgling noises coming out of the fill tube & stop pumping immediately.
You have been lucky so far
Filled it up today and did just what you said and I was able to avoid it overflowing. Do you know what the fix for this is, does the tank need to removed to change the valve or do I need a new tank? I see a lot of talk about people needing to replace their fuel tanks.
They replace the tanks because the gas station nozzle will not put any fuel in the tank. Just the opposite is going on with your vehicle.
roadrnnr
Vermont
The problem is the check valve down the vent tube. Have had this problem many times once a year on my 2011.
The solution is to pull the vent tube up by the filler neck and put some wd/40 down it and then gently blow some compressed air in it to get the tub down to it.
It usually happens to me once a winter and that usually fixes it
M
My2010Ram
Nampa, Idaho
Thank you, I’ll give that a try. I had the truck for just over a year so we’ll see if this will be a yearly occurrence for me.
new2trucks
Minnesota
Just had this happen on my 2010, 1500. thought it was a fluke till i experienced it twice. So, WD-40 in the filler neck. Is the issue that check valve getting stuck and not closing right away? What about Silicon lubricant?
Lsujker
Baton Rouge
Had this happen to my 2008 wrangler years ago. Jeep issued a recall on the problem. If I remember, it was an issue with a return line back to the fill hole. Not fun when fuel dumps out.
roadrnnr
Vermont
Not in the filler neck but in the vent line next to filler neck
Crawl under where you see the filler pipe and you will see a small rubber hose that goes to the tank next to the filler pipe
metalchewy
Las Vegas
2010 TRX4
4.7L
I've had this issue with my 2010 since I got it in 22. Gonna give this a try this weekend. Thanks.
shanmccarthy
