The PCM worked but didn't solve the problem. It ran only mildly crappy at first, then crappier as I went. I thought the computer would have to adjust. Also, I believe that VIN flash is off... it shifted REAL funny - it really lugged probably the gear ratio difference.
I got a CEL as I pulled up to the garage and it was a P0203 again!
No, I don't have a scan tool. I might have to take it somewhere that does. I have used up my mis-diagnosis quota.
I will pick up a compression tester ( I should have one anyway). I may run a wire parallel to the injector #3 wire even though it Ohms out fine. I will price a cam sensor too and see if it falls under the "worth a try" threshold.
I am most grateful for the replies. I ran out of ideas long ago.
