Squeaky door
Phylodog
Arcadia, IN
2012 & 2018
5.7 Hemi & 6.7L CTD
My passenger's side door is pretty squeaky all of a sudden. What type of lube works well and lasts?
ramportin1
Sickest member here
Oregon
Mine had a little squeak at one point and what I did was washed all the inside jams so they were clean, sprayed WD-40 in all the hinges and rollers, took a rag and wiped all the excess back off and then rubbed a real thin layer of multi purpose waterproof bel ray grease that I use on my dirt bike. That was a few months back and still no squeak yet
Deepc6
Long Island
Hemi 5.7 Etorque
I had the same issue with a previous vehicle. I tried the WD40 route initially it lasted a couple of months. From then on I started using white lithium grease, that lasted a few years until I sold it and bought my RAM
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
I use white lithium, but its a PITA to get it into the roller bearing where the nosie comes from.
Two Dog
Ontario, Canada
2014 RAM RCSB Express
I've used Fluid Film with great success on just about everything. $15 a can, but man it works well.
My doors open and close like butter.
H1Chester
Mine is actually doing that right now as well. On the driver's side.
SYKRAMMAN
Banned
Jersey shore
06 Mega
I've always used chain lube from my race quads, works great and it dries so no dirt can stick to it. My last truck lasted years before it squeeked again.
Rampaige
I also use white lithium grease, seems to do well
SYKRAMMAN
Banned
Jersey shore
06 Mega
Mine was doing that. Sounds strange but I put windex on it. No more noise
That's interesting, How long does that last thought? I know it has soap to act as a little lube but you would think after one rain storm it'd be gone, no?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I put Green Grease, can get at Advanced, put on over a year ago, still gone.
JPT
NY
2015 Big Horn
I sprayed white lithium grease in the roller wheels, and rubbed mobil 1 synthetic (red) bearing grease on the rod. I did this to all 4 doors, and they are perfect now. My drives door had a little bit of noise, which is gone now.
