squeeky door henges need help
bloombloom88
Plano, Texas
ok so my doors have been squeeking very loudly when they are opened and closed. ive tried greasing them and i cant seem to make them stop. anyone have the same problem? for a 3 year old truck i dont see why this would happen. i need to make this stop asap, its driving me insane! and not to mention, embarrassing
Musclemckeester
Houston, TX
n/a
n/a
Mine does it, and I've heard other 4th gens do it as well. I have to spray my hinges with WD-40 about once a month to quiet the squeaking.
HemiBabe
DFW
I know it sounds crazy but the best thing to use is gun oil
Nickxxxr
Near Reading, PA
My 11 does it. Quite annoying a one year old truck does it but whatever. I use wd40 as well
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk 2
bloombloom88
bloombloom88
Plano, Texas
ive used wd-40 as well as white lithiam grease and both are just a temporary fix. both will last for about 2 weeks. has ANYONE found the cause or a permanent fix?
amenges
Massillon, OH
try fogging oil. I stumbled across this fix when I went looking through my garage for WD40 and all I could find was fogging oil for my boat motor. So far it's lasted 3 months.
mcamzr
X2 on gun oil or 3 in 1 oil works great. I power washed mine and used the 3in1 oil 4 years ago and it hasn't come back yet. I live on a dirt road so I wanted to make sure I got all the dirt out befor I oiled it.
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Usually the reason they squeak is dirt gets in dries lube and then comes a squeak. I would reccomend cleaning the entire hinge making sure you get all the dirt and sand out then use a white lithium grease. Unless your hinges are bad they will be just like new.
Yes lots of mudding lots of cleaning that's how I know.
