Stainless Exhaust Tip Paint Help!!!
99RamSport360
5.9L Magnum 360
So I am looking at painting my stainless steel exhaust tips black, and as many of you know, stainless is a pain to paint. If anyone has any ideas on how to paint these, and withstand the heat, please let me know.
Thanks
Stangshcky12
Oshkosh, WI
5.9 Cummins
Heat shouldn't be to bad on the tips
They get warm but not warm enough for high temp paint
I would sand them with 320, clean them really well (I use stud called gloss off from krud litter but dawn dish soap and water will work too)
Hit them with an etching primer then the color of your choice
I have an intake torque tube that sits 2-3" from my exhaust manifold that was painted this way with duplicolor perfect match paint and have had a problem with heat after a year now
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
light sand, several coats of high temp black paint, decent drying between coats...let them dry overnight before re-install.
Davy120
fairchild afb
Try flame proof paint from vht, holds up to 2000 degrees, if you cure it properly and that info is on the can and there site
Sent from my MAN CAVE using Tapatalk 2
Stangshcky12
Oshkosh, WI
5.9 Cummins
They won't get that hot
Plenty of people plastidip there tips with out problems
I'd be more concerned about it chipping from road debris and etching primer will give you the best adhesion
On the other hand I sprayed my stock tailpipe black a few years ago with barely any prep and it's still looks good (could just be soot anymore though)
jbmobbs
murfreesboro, tennessee
Well i put about half to 3/4 of a can on my tailpipes and i havent had any chipping or melting yet :).
And as cody said etching primer will give the best adhesion if u do paint therm
