Start out hesitation on 2018 6.7L 3500 when cold
bubbajames
Marysville Wa
6.7L Cummins Diesel
Lately, I've been getting hesitation on my 6.7L from a cold engine during initial start from a stop. It seems to go away once it's warmed up. I'd like to know if anyone has experienced this on their 6.7L, what was the fix, and is it easy to correct?
2018 3500 w/6.7L
Miles: 35700
Thanks,
SouthTexan
408 CTD
Hesitation as in it waits for the grid heater to warm up before starting or hesitation as it makes a loping sound(like it has a mild cam in it) until it warms up?
In regards to the lope or surging idle, I have two tunes for my truck from two different tunes, Hardway Performance and Anarchy Diesel. My Hardway tune never does this no matter how cold it gets, but the Anarchy will if it drops down below 40F.
bubbajames
bubbajames
Marysville Wa
6.7L Cummins Diesel
I should be more clear. After start up on a cold morning, when i put the truck in drive and step on the gas pedal, it hesitates. It's like there is no fuel or it floods, but then it goes without issue. Once the engine has warmed up, the issue seems to go away.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
Is your engine Gas or Diesel, your profile list HEMI
06 Dodge
6.7L CTD
You don't say what cold is, what are your outside temps when this happens, 10 degrees, 30 degrees, are you using Bio Diesel, if so are are you using anti gel additives to help prevent gel problems in temps below 28?When was the last time you drained the water out of the underhold fuel filter housing?
bubbajames
bubbajames
Marysville Wa
6.7L Cummins Diesel
Cold outside is like 35-40, cold start and run meaning I start it on the morning and drive. No additives either. I had the fuel filters replaced about a year ago. I suppose the question about getting water out is how often should that be performed? Does it only accumulate on the fuel filter under the bed or also under the hood? Im still getting familiar with dodge.
Travelin Ram
Probably sticky vanes or actuator in the turbo.
If it was gelled fuel, that is NOT going to clear up immediately when you get rolling and roll into the throttle, it would get worse the more fuel you demanded.
Does your truck get regular hard runs, and do you use the exhaust brake regularly? Keys to keeping the turbo happy.
bubbajames
bubbajames
Marysville Wa
6.7L Cummins Diesel
I began 100% engine brake usage just recently after watching a you tube video about it. Only time there is hard usage is when I tow the 5th wheel. During the winter we are not pulling. My miles driving it is very low, about 5-6k per year.
mtnrider
Georgia
Running the exhaust brake is Not going to save your actuator. I really wish this old wives tale would die.... Sticking turbos is not an issue on the 13+ trucks, it was more for the pre DEF trucks that relied on 100% EGR to reduce Nox.
The actuators are failing because the components on the circuit card were not spec'd properly and they are failing from use and heat cycles.
Run the exhaust brake if you like it but don't do it thinking it will save your actuator....
As far as you "issue", did this just start? How often do you drive the truck, does it sit a lot? Is it stock of tuned? Are you trying to give it aggressive throttle or easing into it? These trucks have several operating modes (that switch and are transparent to the driver) and it would not be happy if you got on the throttle heavy when in the "cold" mode. It's done to protect the engine.
bubbajames
bubbajames
Marysville Wa
6.7L Cummins Diesel
Hi, I don't drive it a lot but when I do I'm easy on the throttle. It's a stock truck all the way. This issue started up about 3-4 weeks ago. I was asked if I drain water from the fuel filter. I do not have a water in fuel indicator lite on my dashboard. Should this still be done and would it help? There is a vent filter that goes under the plastic cover on top of the engine. I guess this replaced the PCV valve. Could this be the issue?
06 Dodge
6.7L CTD
Drain under the hood filter at least every 2-3 months being you don't drive lots of miles, monthly if using Bio Diesel... IMO its a good idea to use additives like year round, more so in the winter time like Power Service Winter to help prevent problems due to water, fuel additives also help keep fuel system clean & boost Cetane... IIRC fuel filters should be changed every 12 months or 20K and buy good quality filters like Cummins Fleetguard, don't buy the cheap fuel filters made in China or Fram....
Crazyjoe
fla
cummins
I'm of no use to you(and too late). Looks like no one else was either. Did you ever figure out, your problem?
bubbajames
bubbajames
Marysville Wa
6.7L Cummins Diesel
I did resolve the problem, and it's not coming from the service folks. It was fixed within the first tank of diesel that I used archoil AR6400-D diesel fuel cleaner, followed by AR6500 diesel treatment. Once I began using this, all my issues went away. I now use this with every tank, but can probably go every 2-3 tanks now. Runs sweet!
ricky_bobby
Wake County, NC
6.7L Cummins
I agree with a quality additive (I use Hot Shots EDT) - I use it every couple tanks and keeps mine running great -
southalum
