starting hesitation video of my 2014 Sport
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
A video of the startup hesitation I'm getting on the 1st startup of the day. You can hear right before the engine fires up. Doesn't do it the rest of the day....only when I have the initial start. The dealership "doesn't hear it" when I leave it there overnight. It doesn't sound right to me. What do you guys think?? Is this normal for a Ram?
http://m.youtube.com/watch?v=fusdPxplqDg
2014StormTrooper
Aggieland, TX
2014 Ram 2500 Longhorn 4x4 2003 LY Evo VIII ER Built 2.2L
6.7 CTD / 4G63
my 14' sport with the push button start pretty much sounds the same when i start it
S2kiHemi
Houston TX
My 09 does the same thing on cold starts. I think its normal.
mmwaggie
can confirm mine does this as well. it's always calm before the storm.
jmgak47
Banned
Hemi 1500 Express QC 8 Speed
Mine does the same and have heard others talk about it also.
jmgak47
Banned
If they don't fix it soon I am going to wire up a switch. Pin #16 is the power and where you would wire the switch inline.
jmgak47
Banned
Turn off the power to the Trinity completely eliminating the battery drain.
Sir John
Sir John
Buffalo, NY
Thanks for the replies. I wasn't sure and yes, it is less than a second.
regularcab2500
Buffalo
5.9 Magnum
my 6.4 even does that a little..when I first bought it a cold start set off a code for the check engine light showing a misfire in cylinder 6 but a PCM flash fixed it..
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Yes, my 2009 will do it also. Probably just the system catching up to itself with the TIP start.
Jmhm17
Massachusetts
5.7L HEMI
mine does it too. but if I prime the fuel pump it wont do it, unless its really cold and its been sitting for a while.
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
My 2011 and 2013 did/do this. Only the first start in the morning. Otherwise fine...
ChloeBrooks
