Starting issues
Behodges82
Iowa
04 ram 1500 hemi would turn over replaced the pcm and ignition switch no security feature. When i bypass the asd relay it turns over and wouldn't fire off. A buddy came over and we decided to spray starting fluid in the tbi and it fired off and idled rpm was high all the warning lights were flashing red lightning bolt was aluminated and was in limp mode. I was thinking bad icm this one has the fcm attached to the icm. Buy doing some research it could be that could be a bad ground and so forth. Anyone have this issue i got a icm from the junk yard but it was out of a 02 ram and 2 of the molex plugs were different. Anyone have this issue? Also in need the wire diagram for the pcm pin outs so I can figure out what wires are grounds asd specifically the asd relay andc do forth fuel pump was running as well. Thank you in advance
joshhhh
