Stock fender flares 2018 Laramie
Psu2ski32
Philadelphia, PA
Hi there. Have a 2018 Laramie with the stock fender flares on them. It seems they are pulling away from the body already. How easy are these to fix? How would you go about it?
Ohio5pt7
Ohio
No experience but I cant imagine a easy fix. Heat will likely warp it or screw the paint. Pulling it off without loosening the tap will likely damage them and the sheet metal. Maybe acetone and light pressure? Safest bet would be let the failure happen till its sorta loose then worry about it.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Cableman
Longisland
I have a 16 laramie, mine were pulling off in some places.
I used flex glue in the areas it was coming off, cut the smallest piece off tip enough to squeeze it behind. I think i flattened tip with a hammer. Worked great
Pull Ya
Cedar Creek, Tx
Remove the screws and then slowly remove the flares. They are held on(not very well sometimes)by 2 sided tape. Clean all the old tape off the flares and the body where the flares come into contact with the body. One thing you can do, it isn't a must but some have tried it and think it works well. You can install some 3M clear film on the body where the flare contacts the paint. This will insure that the flares don't rub the paint. If not, you need some two sided 3M tape and some adhesion promoter. Put the adhesion promoter on the fender and replace the tape on the flares and install the flares on the fender. Replace the screws. If it's warm outside when you do this it seems the tape sticks better.
Jay
