stock height MAX tire size?
Ramitiner
U.S. ARMY VETERAN
NJ
hey guys, would Cooper Discoverer AT with a size of 275/65/20 fit at stock height?
1500ram12
5.9L Cummins
1500 or 2500?
2018 2500 6.4L Tradesman
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
4x4 express if that matters...
1500ram12
5.9L Cummins
1500 I'm not a100% sure. 2500 no problem. Probably could just might have some rubbing on the plastic inner fender. Hopefully someone with a 1500 will chime in
1500ram12
5.9L Cummins
What size is on your truck now?
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
the stock wrangler SRAs 275/60/20
1500ram12
5.9L Cummins
Honestly I don't think you'd have a problem. You're not jumping up 2 or 3 tire sizes.
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
im thinking its ok as well but ive had some vehicles where it was a bit of an issue with rubbing when I turned
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
I have them on my truck, stock 20's, big horn.....
Nokian 275/65-20E....34" tall, BARELY rub at 3/4 on the headlight access panel because I lost the push tab.....no issues at all....way easier to find in this size around here as they are a standard size.
Sent from my SM-G892A using Tapatalk
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
gonna get a set of those tires with less than 50 miles on them and moto metal wheels for 550 and tpms inc!
Ramitiner
Ramitiner
U.S. ARMY VETERAN
NJ
oh and they were "adventurer" not discoverer... whateva, they are brand new
Tracy in IL
Moline IL
3.0 diesel
a 33" tire will fit with no issues. Going to a 34" might rub on turning, plus could lead to long-term issues with tranny heating up, unless you manually keep it in 7th gear. Also, rear end gear comes into play. Safer with 3.92, iffy with 3.55.
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
it won't hurt the transmission at all. the tie is 1" taller, the difference is a 1/2" extra side wall. all tires are different , some mud terrains in a 275/60r20 measure 33.75". a new vs worn out tire can differ over 1". your transmission is designed for a small tollerance.
ameer73
