Stronger front axle shaft
OhYou_
Does anyone know if they make stronger axle shafts for a ram 1500?
I snapped one this weekend, and I'd rather not just put another stock one in if its just going to break again.
Part number is C205F, its just a 6 inch shaft that sits in between the diff and the half-shaft
Jamesq87
Alabama
Ifs right? When I pulled up that part number, that's what showed up. I'm not sure of any stronger ones but if you off-road, I would consider a solid front axle swap from a 2500 or a 1500 megacab. Just my 2 cents.
2006 Ram 1500 SLT Megacab
5.7/auto/4wd
2" lift,33's,minor exhaust tweak. (For now)
O
OhYou_
Yes, IFS.
Didnt know the 1500 MC had a solid axle.
I do off road a bit with it, but mostly faster trails, desert style. It was the first time I tried rocks with it, and it snapped almost immediately. Looking at the break, its all porous and looks like it was made of cast iron...
There's definitely room for improvement.
Problem is that aside from OEM, there's only cheap aftermarket ones
And for what that's worth, I could just go to a junkyard and pick up about 6 OEM ones for the same cost.
Jamesq87
Alabama
Yes, IFS.
Yup. I think it's the 2wd megacab that doesn't use it. Rocks will definitely do damage. I've seen it all the time on video clips. The truck does fine on everything else then it gets in rocky areas and *snap!*
5.7/auto/4wd
dterrel
