Stuck bolt
IJW84
Anybody know any tricks to get the lower strut bolt out. This is a 2008 1500
IJW84
IJW84
Tried that, but maybe I didn’t hit it hard enough. Although I did hit it pretty hard several times. I’ll go try tomorrow if no better way turns up here. But I suppose thats all there is to do is bang the **** out of it
smoothee
St. John's, NL
Probably have to cut it out and replace the bolt and bushing. Pretty common in the rust belt especially, unfortunately. That's what I had to do after heating it/soaking it/and beating the **** out of it. The sleeve in the bushing was pretty much welded to the bolt. Coated new bolts in anti seize and haven't had a problem since
Elvira
Somewhere
You can try soaking well in a rust penetrating fluid. If you have an air chisel, that may be the ticket for breaking it loose. The bushing being part of the control arm.Hitting it with a hammer, the rubber bushing is absorbing most of the shock. You may have to cut the bolt, then tackle the job of removing the left over piece in the bushing and driving it out. If you use torches to cut the bolt, keep the bushing cold so you don't burn up the rubber. It will come out with lots of patience.
turkeybird56
Central Texas
The minute I read the post, thought BFH. U guys do this more, just a thought: Is the Strut still attached at the top putting a force down on the bolt? If so, could U soak the bolt good with wateva oil, put a jack under the strut edges (under the bolt) to take some of the weight off the bolt then whack a mole on it? Just thinking out loud.
CAVEAT: Looking at the bushing, is it threaded? Is so, whack a mole just gonna bust everything outta there and need to be replaced, IMHO. If threaded, oil it up, let soak in, then put a breaker bar on it and heat it up with propane torch and turn??? That would be my approach if threaded, instead of whack a mole but U know sometimes, replacing a few bushings be easier, just spend $$$.
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
You may need a strut compressor to relieve the pressure. Won't take much but you'll be able to move the bolt freely after pressure is release. That looks nice and clean.
retired
montana
what I do is take two nuts and thread them on and lock them against each other and use your impact wrench from the threaded side where you can push hard will turn it out.
DILLIGAF
Canadian Forces
Canada
If all else make it liquid lol.
Thats where my 1/2 Milwaukee impact comes in ;)
Ive never had issues getting that bolt out with it...Or any bolts for that matter. lol...
I am a Milwaukee ***** tho !
Dinky
Oregon
Yeah its a beast For sure. Cute collection but you will need a few more tools to beat my collection lol.
shrubs
Nolensville, TN
I have had similar issues as mentioned. Chopperman and retired have techniques that appeal to me.
I see no paint. Try to let a small amount of brake or hydraulic fluid creep in to the bolt surface as you go.
Malletizing may work but…….
DILLIGAF
Canadian Forces
Canada
You mean like Chop Saw, Framing framers , work lights ect.... I got all those to. I work construction ;)
IJW84
IJW84
Where did u get bushings , Did u have to use some kind of press to get new bushings in? Nothing at the dealership
smoothee
St. John's, NL
The dealership will tell you that you need to replace the whole control arm. I picked them up at Napa I think, but any local parts store should have them. And I used a ball joint press, something along these lines
But you can rent them too for next to nothing
metalchewy
Las Vegas
2010 TRX4
4.7L
I have the same issue. Rubber spinning on the lower strut bolt when taking it out. Rented a ball joint press when i picked up the bushing.kits. After I melt the rubber so the bolt will come out going to remove the old one and press in a new one.
Glad this idea was on here. Was planning to take the air Chisel to the remove the old one and use the bolt to self press in the new one. Thanks
metalchewy
Las Vegas
2010 TRX4
4.7L
That wa so much fun.... ....knuckle breaking fun.
Bolt seized in the inner sleeve. Cut an ear off the strut and the bolt head off the other side
Once it was out, dremel and a pointed hardened grinding bit got the outer sleeve so I could drive it out.
Ball joint press almost fit, but it is in now...
Even though I bought another side, when I do that side, I will not be replacing it unless it is shot...
