Yeret
Professional Procrastinator
- Oct 2, 2014
- 1,002
- 212
- 1999
- 5.9 Magnum
As you may know (General Discussion), pops and I were working on the plenum repair on my truck.
And after successfully removing 10 of 12 bolts (those rear corner ones were a PITA, but I get 'em) the final 2 front corner bolts busted on me (*** *** *** *** ***!)
Today, we gathered some stuff to try and attack the shafts that are sticking out of the head. After having no luck with a vice grips and a torch (and I had the ******** soaking in penetrating oil for the last two days), we resorted to trying to drill them out.
Center punch, 1/8" hole later, the 1/4 inch bit wouldn't bite through (these were left-handed bits with a reversible drill), so we went straight to an extractor that would fit.
Pops used a crescent wrench to crank it in, went in no problem. He then tried cranking it out and then SNAP! ****ing extractor tip busted right off, flush with the bolt surface...
What are my options now? Best we can think, the heads gotta be pulled and taken to a machine shop. Really could use some advice here 'cause this truck is my daily driver. I can borrow Gramps' truck for now, but I really REALLY can't bank on driving it for more than a week...
For those that are curious, the plenum gasket was TOAST. What was left broke apart like cracked china. After flipping the intake upside down and removing the pan, there was a strong shot's worth of oil sitting in there. The pan was completely saturated in oil. All I can say is WOW...
