Zoe Saldana
I'm doing 100k spark plug and coils change.
Most of the plugs are hard to remove - meaning you break the initial resistance and you still have to use force to get them out.
One plug is stuck meaning it got HARDER to turn as I went along. I tried some penetrating oil an no luck. I stopped and I don't think I moved the plug out much. I heard a bit of a screeching sound at one point. I became afraid I might really screw things up if I continued.
The truck is running smoothly - no codes.
Any suggestion?
How screwed am I?
Any suggestion?
How screwed am I?
