Subwoofer Recommendation
barimpact3
Magnum 4.7 Flex Fuel
Hey guys, so I have a 2007 Ram 1500 quad cab and have a 12 inch sub box under the seat from Amazon with a Kenwood 3013 paired to a Boss 1100 watt amp. This sub is pretty good but it really doesn't hit low notes like I'd like it to. Is there any other subwoofer that would fit in that box that would produce better, stronger lows, or do I need a fiberglassed box?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
What's the airspace of the enclosure? Depth?
2nd, I would find another amp, the Boss amps don't do NEAR rated power.
QwikKota
5.7L
Is the box ported? That can loosen the sound up as well but usually a non-ported 12 will still go pretty low.
Etroze86
Grand Forks ND
yep need a little info on air space, the ones that come to mind cost significantly more than anything in kenwoods lineup but play low in sealed with authority.
DoubleTap
Las Vegas
Well first thing I would change is the amp. Boss is not a good manufacturer. And as far as subs go I would check out a sundown audio SA 12" sub. They are one of the best subs on the market and you get way more for your money when any other brand for subs with sundown audio.
Seraphim38
5.7 gas
Sundown subs are exceptionally well known for handling a good amount of watts. The amplifier isn't likely to change the tone of the driver dramatically, though powering it properly can make a difference if it is underpowered or running off a really cheap amp. There are pretty decent amplifiers that can be bought on a budget, maybe $200, that would play rings around that Boss. Depending on how it is setup, a new amp may or may not make a huge difference.
Chances are the box is too small, and it is sealed. The bass extension will be limited by a sealed box. It will play nearly another full octave lower in a ported box, compared to a sealed one.
Graygoose
Oklahoma
Convert, for now.
small
You could change subs, but if the real power isn't there, you will still be disappointed. Boss rates max power, when they get hit with this;
Seraphim38
5.7 gas
nice one, Gregoose.
Being on the inside in a brand, and being exposed to product competitive matricies and then tearing down the products to determine what amplifier raw components they possess, it is clear that some use conservative wattage RMS ratings, some use peak, and some use what we call "marketing watts". This type of a claim is something like, the amplifier chipset could have done that much power, except the board doesn't have a power supply with enough juice to ever get the final output to be near that level.
Ironically, in contrast to car audio, the most popular bass guitar amplifier and cabinet combo in the world is the Ampeg SVTCL 350 watt tube amplifier, with a cabinet containing eight 10" woofers. It is so obscenely loud that you can't turn it up anywhere but in a venue that seats over a thousand people, and even then it will probably be too much. 350 good watts of power can output enough volume and sound quality to astound pretty much anyone. People who say you need a thousand watts plus in order to have sufficient bass in a car are dealing with poor enclosure designs, inefficient drivers, amplifiers that deliver nowhere near the rated power, and other compromises.
Graygoose
Oklahoma
Convert, for now.
small
Inside is what tells the story :D
adurm
FL
2015 RCSB
I agree with everyone else, get a new amp and make sure the box is big enough. 1-1.25 cu ft inside dimensions.
Seraphim38
5.7 gas
HAHAHA GreyGoose. Nice one.
I think I just threw up a little.
