Sympathetic vibration TSB
British Bulldog
Jacksonville NC
SST HO
Just a note here for fellow 5th gen owners.
I have had a continual ‘drone’ develop in my 21 and while it was under warranty reported it.
Local dealer is brilliant and has spent hours on it. Consulted FCS TECHNICAL DEPT.
At FCA instruction replaced the amp for noise cancellation. No joy.
So there is a TSB out for this, addressing this drone at 45-50 mph. It involves a plate to stop front of truck bed below window vibrating sympathetically. They install a 1/4” plate on front of bed wall. You do see two bolts inside bed as a down side. Not judging, looking for opinions etc etc just info if you HAVE this problem. I haven’t decided yet to go ahead or not so can’t tell you if successful. They do not remove bed…….
Apparently mostly on beds with multi function tail gate? Not uncommon or unheard of.
Clive
Musky Mike
NC
I had a drone decelerating down hill with MSD on. It was random, took to the dealer twice and they could never duplicate it. Took me a few years to figure out, but when I have some rubber made bins in the back seat, that when the drone would happens. Take them out and the drone stopped. Who would of thought some stuff in the back seat could interfere with Active Noise Cancellation system.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
If you have an old sleeping bag or large pillow, stuff it down between the bed and cap and go drive it. This should tell you if the plate will be a solution.
chri5k
USA
Diesel
I had a drone decelerating down hill with MSD on. It was random, took to the dealer twice and they could never duplicate it. Took me a few years to figure out, but when I have some rubber made tots in the back seat, that when the drone would happens. Take them out and the drone stopped. Who would have thought some stuff in the back seat could interfere with Active Noise Cancellation system.
You had children made of rubber in the back seat? That seems kind of weird.
18harvest
huntsville
I just used a bypass harness on the noise canceling box under the seat.
with earlier Rams, they used vibration dampers
they stopped sounds from traveling along the frame
Mass Damper - Mopar (68051255AC)​
2013-2024 Ram - 68051255ac
Then FCA went to this
an article about it
Much like noise-canceling headphones, these Active Tuned Mass Modules create a tiny vibration that counteracts those disharmonies, making the result as smooth as ever. They are fixed to various points on the truck’s frame, utilizing small electric motors that turn an unbalanced weight shaft. Their basic functionality is just the same as the vibration module in your phone.
British Bulldog
British Bulldog
Jacksonville NC
SST HO
Yes. The dealer checked and cleared all those, plus the amp . That was replaced, but didn’t cure it.
This is why I am procrastinating on allowing my bed to be drilled. All this, if successful, will do is ‘mask’ the noise.
I may just do as someone suggested and stuff a quilt in REALLY tight and drive on a quiet rd!
I could also wedge a piece of plywood inside with something, again, just to try it out.
Honestly, I’ve had it checked, all drive components and critical things ok, it’s documented under warranty, turning up the radio and ignoring is beginning to work for me!
British Bulldog
British Bulldog
Jacksonville NC
SST HO
I’d like to believe FCA engineers have thought this TSB through, but even the dealerships team find this an eyebrow raiser.
British Bulldog
British Bulldog
Jacksonville NC
SST HO
Just to moan and groan.
Update on this anti vibration plate TSB. Don’t bother. It is a 1/4 steel plate bolted with two 8mm bolts through front of bed, behind cab. If you imagine the vertical raised contours of bed, about 3 or 4 inches apart, it doesn’t even span two or three, just the one. Made no difference whatsoever and they didn’t even paint the plate! Bare steel.
Wasted my time and dealers.
I’ll live with it! Might even take the flaming thing off and plug holes. It does nothing and for the life of me I can’t see how it would. It doesn’t provide any adequate support or span. Basically touches a 1”x4” piece of the bed.
KingJ2
Calgary
I purchased my truck last month from a Nissan dealership. They told me they put on brand-new tires (General Tires Grabber ATP) to pass a Pre-purchase inspection.
I also noticed a droning sound from the front axle when driving at 100 + kph. At first, I assumed it was caused by the brand-new tires, but I still brought it to a RAM dealership to get it checked over, amongst other things.
View the attachment for the dealer's comments to see if you recognize yourself with the same issue. Attachments 1-2 from the first visit and attachments 3-4 from the second visit.
During the inspection, the tech noticed the right side bearings were replaced by aftermarket parts. They changed them with OEM parts, but the noise continued.
Ultimately, it wasn't caused by the noise cancellation system but by the new tires. Indeed, the vibration and road noise have dropped since last month, as I am driving my truck, but they are still present.
