Tachometer only works at high RPMS
Jimmy A
Coarsegold, CA
I've got a 2006 Ram 1500 SLT 2wd Quad Cab Big Horn Ed. with the 5.7L Hemi and the tachometer does not work at idle or low RPMS. Driving around town, doesn't budge. But jumps into action anytime I'm accelerating hard.
Anyone know what causes this? Should I try resoldering the connections points for the Tach? I assume if those were bad it simply wouldn't work at all.
Thoughts? I'd really like to avoid buying a new cluster.
Thnx
Fast69Mopar
Thnx
I would at least remove the instrument cluster and check the connections for the tach. If you find the solder points to be inadequate then go ahead and do the repairs.
Karlsweg
SW Florida
Common problem on the 06s. Do a google search. There are a couple good videos on the “fix”.
