Tail light problem
Rroop32
5.7l Hemi
Been having a problem with tail lights recently. Truck is a 05 QC 5.7 4x4. My issue is the brake lights randomly get stuck on. I've been through 3 brake light switches and the issue keeps occuring. I have also reset the switches (even though they are 1 time use only) it happens atleast 3 times a month. What I've noticed is that when I disconnected the negative battery terminal for a few minutes and hook it back up, they work normally. I'm starting to think this is an ecu issue now. Any one else experienced this before or heard of this? Any one know what could possibly be causing this?
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Not sure if the 05 taillights are computer controlled or not. If they are then it is most likely an ECM problem. Might want to find that out first.
Wchnu
South Louisiana
My 03 is doing this. The brake lights on the back of the truck stick on for a few seconds to 40 or so seconds. The third light works perfect. Not sure. Where to start. Any Ideas ?
