Tail Light Wiring
Space_Cowboy
I'm installing some LED light strips in the bed of my 2015 Ram 1500 and would like to source the 12v from the tail light. The light connector has 3 wires (white, white,black). Can anyone tell me which is the 12v hot all the time even without the truck on?
Thanks!
kad
Hudson Valley, NY
5.7L HEMI
I don't believe that any of the taillight wires would be hot at all times. Most people adding aftermarket bed lights either tap the 12V from the trailer connector or the cargo light in the 3rd brake light housing.
-K
S
Space_Cowboy
Does that "chassis" have anything to do with that wire that is under the left chassis that that Dodge capped off from the harness? I believe I've seen some chats about it and they are calling it the "ARE" cap wire.
Thanks
S
Space_Cowboy
Can anyone confirm that the capped off wire on the left side of the chassis close to the bumper is a continuous 12v source for what I want to use it for?
Thanks
EagleChief
Oklahoma
2014 Big Horn
Can't answer your question, but can you get a tester at the any of the stores and see if there is power to it? They are pretty cheap and easy to use.
Ramtruck16
Blue Springs Mo
You might find a constant 12v connection in the 7 pin harness for the trailer brakes...
S
Space_Cowboy
Thanks for the replies... I'll check the trailer connection harness.
mikeynosikey444
