Tailgate light bar
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Just installed a tailgate light bar. Buddy gave it to me for free, score! I'll post pics as we go a little
Sent from my XT1096 using Tapatalk
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
it's such a simple addition but looks so good on a truck as long as all the leds work lol
Sent from my A0001 using Tapatalk
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
One is out on the far left due to my ******** installing it. I cracked an LED...
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
uploadfromtaptalk1438879519174.jpgright blinker (shows change in intensity) and brake. Also has white LEDs for reverse uploadfromtaptalk1438879563363.jpg
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
That's what i said too lol
I should put one on my truck tho too. How'd you get around the crank hole for the spare tire carrier?
Two screws and that rubber fitting comes out and the bar will fit flush
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Zip tires ok but wire nuts no thx. I splice everything with the crimp connectors with built in heat shrink
This is temporary. Im re-running wires later I just wanted to get it in quick. All I had was wire nuts I didn't have anything else to use. (I learned about these damn wire nuts while doing my halos... Had 3 fall off and the rest got corroded and crap)
bassslayer25
East, Kansas
5.9 360 V8
Solder and Shrink wrap FTW!
Best looking and best way but its too much of a process. Have to get a heat source etc. I like butt connectors cause all I need are some wire strippers and some electrical tape and im good to go. :favorites13:
MagSport
South Carolina
Wire splicing and electrical tape FTW! Connectors are for *********!
:hidesbehindsofa:
thz71
Wow next time you should pay someone to do it right.
