take advantage of what ye factory gave you
the codes
Houston, Tx
Magnum 5.2
well just wanted to take a second to mention something I think a lot of us forget about.
Since the day I got my truck, approx 3 years ago, I have been on a quest to improve the ride, which I found to be bone shattering after hitting the smallest bumps. Replaced shocks, and coils, and added a sway bar on the rear. all helped, but nothing to significant.
was getting ready to throw in the towel and start replacing **** left and right, ball joints, idler and pitman arm, control arm bushings, etc, and then upon inspection discovered that the factory equipped 4 greaseable joints! so took the 5 minutes to pump grease in there and the ride is incredible in comparison. joints must have been bone dry. I am thoroughly enjoying the ride now.
my friend with a 2002 furd says his truck came with nothing greaseable. so I consider us to be lucky.
I plan on replacing the dry rotted sway bar bushings and the sway links and calling it done!
Tapatalk Addict
the codes
the codes
Houston, Tx
Magnum 5.2
the joints? they are very noticeable. large, silver nipples.
Tapatalk Addict
Chewy
Bettendorf IA
V8
Many manufacturers have gotten rid of zurks because when you drill a hole in something it weakens it. Plus today's greases last a very long time. My '98 F150 doesn't have any either and I've replaced NO major suspension parts. Only shocks.
Sent from my iDevice using data nodes and algorithms.
New Rhino
