TB Bolt Holes
adventurer
Amman-Jordan
2010 and 2006
Hemi 4X4 CC and Hemi 4x4 QC Sport
I actually did just that. Its slightly longer but not by much. It threaded and tightened. I still get a whistle but I think that's normal now. I sprayed carb cleaner around the TB and the idle didn't change which I assume it would have otherwise. I may have a small leak around the hose. But I can deal with that.
on the move..
Glad it worked for u . i ll do mine the same way later on.
popcenator
popcenator
Omaha, NE
If I remember I'll get some pictures of the bolt I used next to the stock bolt.
on the move..
ATXHEMI
Round Rock Tx
Glad it worked out for you. Not sure why they make the intakes plastic. Damn cheap asses.
popcenator
popcenator
Omaha, NE
Yeah I was not too happy when I saw it was plastic. Hopefully I'll never have to remove that again. Thanks for the advice guys!
UNSTOPABLE
Culiacan, Sinaloa Mexico
Hemi 5.7 liter
Man Sorry for the my need it..... so i have the same problema in my 4 hole Intake, curiusly my Throttle body is really hard, whit my 2 hands i did can move or feel it bad, but.... the 4 bolts are loose, not like to move whit my hand, but loose for the tool....
i hope understand me..... i´ll like to see the bolt than you used in your truck, or the bolt especifications...!!!
thanks so much....!!!
popcenator
popcenator
Omaha, NE
Hey, sorry for the late response, been away from the site the last few weeks. I'll go digging to find the bolt. Basically the bolt just needs to be a little wider, the thread was also a little more aggressive.
Edit: here's the bolt on the right, stock bolt on the left. Don't know the actual dimensions, I just went to a fastener shop and have them the stock bolt and they found that one to match. Just grind off the bottom.
on the move..
RamHemi5.7
Gilroy Ca
2013 Quad Cab
Hemi 5.7 8 Speed
are you frickin kidding me? THOSE are the kind of bolts mopar uses for the throttle body?? why the heck not a regular fine thread bolt? the intakes SHOULD have been designed with a metal threaded insert for a metric treaded bolt. imo...
popcenator
popcenator
Omaha, NE
Yeah, it's pretty irritating how easy it is to strip the hole. I can't believe they thought it was a good design.
on the move..
audio1der
Airdrie, Alberta
I must be lucky, as I've had my TB on and off 3-4 times and have had no issues with stripping the crappy plastic bolt holes.
popcenator
popcenator
Omaha, NE
Yeah because it took literally no effort to strip it.
on the move..
ChloeBrooks
