Thanks for the add 2018 ram sport AC issues
Clodzilla
Canada
Thank you for the add I have a 2018 ram sport with duel zone climate control on AC mode blows not cold but regardless of setting blows hot on passenger side checked 3 of the 4 actuators wondering if it’s the 4th actuator and where would that be located cheers
Jeepwalker
WI
2012 Reg Cab, 4x4
How did you check them? Which one *didn't* you check? (location)
C
Clodzilla
Canada
I located the one behind the lower glove box and the 2 behind the radio Center console they were all working there is a forth one I’m hoping it’s not between the fire wall and the HVAC it much info on the web about the 2018 model
jws123
nj
Did you also check the charge on the system? If its low on refigerant one side can blow cold one will blow warm most common issue blend door acuators do fail just odd to have one fail on a truck that new.
C
Clodzilla
Canada
I did the refrigerant is full and the 3 actuators are good leaves me thinking it’s the 4th actuator wondering the location it’s accessible without ripping apart half my truck
Think you're taking apart your truck to get at the 4th one,pretty sure the dash and hvac unit has to come out to get at the one against the firewall
a few of the dual zone HVAC systems have a 5th actuator, that one is against the firewall, the Ram Vans have 5 actuators
I don't know which of the Ram pickups could have them.
In your case, pull both glove compartments
Then look up, the 4th actuator moves the Recirculation Door
while you have the glove compartments out
check your Cabin Air Filter
it keeps your A/C condenser cleaner
I am just thinking,
If your actuators all work , i would change the CAF out, with a another one
many owners buy the CAF from Geno's Garage
or
Fram Fresh Breeze Cabin Air Filter with Arm & Hammer Baking Soda,
others prefer a CAF with charcoal or carbon
the CAF is fairly easy to change out, finding the door clips, takes bit of finger work
One more thought
your system may be one that has a RESET
HVAC Manual Recalibration below
With the vehicle running set the HVAC blower to low
-Press and hold the recirculation button on the HVAC Control Head for 10 seconds and release.
-Now press and hold the recirculation button on the HVAC Control Head again until the recirculation LED begins to flash, then release.
-The system will perform a brief recalibration and reset faults
mvm2
